Текущее время: Вс окт 11, 2026 6:13 pm
Начать новую тему Ответить на тему  [ Сообщений: 42 ]  На страницу Пред.  1, 2, 3
 Заголовок сообщения: Re: Avensis 2001-06 (T22-Facelift-model) Steering Noise. (Video)
СообщениеДобавлено: Вт окт 18, 2011 8:58 pm
У вас особенный случай. Я не знаю. Разберете и решите проблему.
СообщениеДобавлено: Вс дек 11, 2011 11:50 am
Вспомнил. Ну и куда же пропал наш заграничный друг? Чем все закончилось?
СообщениеДобавлено: Вс дек 11, 2011 6:47 pm
Bocaj писал(а):
Alex27104 писал(а):
I have tried this but did not work!
I was at a Toyota Specialist today to check the problem.
He knows where the problem is!
The squeaking seems to come from a plastic ring which sits around the steering wheel hub.
He told me that it is NOT the Steeringrack and NOT the Steeringcolumn! (They are fine!!) :D
Next week it will be fixed! :wink: (Should not cost much!)
It's bin a while, but here is an update!
After the Toyota Specialist did his job the sound was not totally gone but the sound was different and not so loud as before...
It was okay for a while but now it is back again. :sad:
Now he wants to drill holes in the steeringcolumn to lubricate the rubber sealings in the column...
I still have to make an appointment for that! But because it's cold outside the sound is also different. (Not so loud.) So the tempeature outside does matter also...
That got me thinking again that it is something outside the driverscompartiment... :roll: I'm still thinking about the streeringrack... but 1st we are drilling holes! LOL
СообщениеДобавлено: Пт янв 06, 2012 1:13 am
hoi, Bocaj
Waar kom je vandaan? want ik woon ook in NL dicht bij Breda, en ik had het zelfde probleem met stuur geluid )))
СообщениеДобавлено: Пт янв 06, 2012 1:20 am
sem писал(а):
hoi, Bocaj
Overijssel.
Hoe is jouw probleem opgelost?
Het piept nog steeds.
De ene dealer zegt stuurkolom en de andere dealer zegt stuurhuis...
Ben nu bij een toyota specialist geweest en die heeft alles gesmeerd... echter nog zonder resultaat!
Zelf denk ik toch dat het stuurhuis de piep veroorzaakt maar is nogal duur...
СообщениеДобавлено: Пт янв 06, 2012 8:10 am
Это уже не транслибельно для большинства. Неужели не помогает смазка?
СообщениеДобавлено: Пт янв 06, 2012 8:48 am
I put grease everywhere but still steering noise...
We are now at a point to replace parts, or not. Because we can do 3 things!
I can live with it and do nothing or i can replace the column or the rack and both are expensive because i cannot do it by myself!
СообщениеДобавлено: Ср янв 11, 2012 9:50 pm
I can't beleave that lubrication of problem places, have no result. May be you don't understand us, where to spray on.
СообщениеДобавлено: Ср янв 11, 2012 9:57 pm
Whahahaha, do you really mean that? :wacko:
СообщениеДобавлено: Ср янв 11, 2012 10:16 pm
Sorry, but the noise in all video is like that we have on rubber seal. If it's really wrong, you can try to remove ignition lock and listen again.
СообщениеДобавлено: Сб май 19, 2012 9:53 pm
Car is sold!
Is going to Afrika :D
End of story!
СообщениеДобавлено: Вс май 20, 2012 1:41 pm
Bocaj писал(а):
Car is sold!
End of story!
Удачи! :)
[ Time : 0.036s | 30 Queries | GZIP : Off ]
